odd shifting when cold
Old Oct 1, 2008 | 08:55 AM
fishlessman's Avatar
fishlessman
Default odd shifting when cold
the tranny seems to not shift as quickly when first starting out when cold. going from first to second it climbs to almost 4000 rpms before shifting from first to second. after a few minutes of driving its back to normal. is ther a linkage or vacuum line that could cause this, maybe a quick adjustment. trucks just over 60 k and the fluid was changed about 33000 miles ago to type 4, about 3.5 years ago.
Old Oct 1, 2008 | 12:38 PM
codydakota's Avatar
codydakota
there is a kickdown adjustment, but I don't think that would help as your trans acts up when cold and not hot, if the kickdown was out of adjustment, I would think it would constant regardless of temp change. You could try warming up the trans before driving by shifting it into neutral and letting it sit for a few minutes
Old Oct 1, 2008 | 01:32 PM
fishlessman
maybe i should bring it in for a fluid and filter change, didnt change the filter last time and see if there is anything in the pan
Old Oct 1, 2008 | 06:11 PM
fwtc's Avatar
fwtc
yep change the fluids and filter. try synthetic atf, it works the same at 30c or -30c (roughly 90f to -25f).
