93 Dodge dakota, brake problems
when we were in south dakota for hunting, the ani-lock and brake lights both came on. the brakes seem to work with no problem, he thinks it might be a fuse, but also we were low on brake fluid, he filled it and it is still on any one know what it might be??
the truck is a 93 dodge dakota v8
thanks
thanks
There is a switch that is on the porpotioning valve that swtiches on when there is a driffernce of pressure inbetween the fronts and rears. The switch can be stuck. Take off clean up and see if it works. If not then you got air in the lines. You will need to bleed the brakes.
