Couple of Problems
Old Nov 13, 2008 | 08:14 PM
Raven7979's Avatar
Raven7979
Default Couple of Problems
I have recently noticed a drop in gas mileage. I was getting 23-26mpg now i get around 17. Also if i push the gas and let off quickly the truck sputters and jumps then dies. Any ideas. I have a 95 with the V6.
Thanks.
Old Nov 13, 2008 | 09:40 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Do you have any check engine lights? It can be multible possiblitys. From a map sensor to O2 to IAC valve. Does it do it when its cold? warm? all day? all speeds? Need more info!
Old Nov 13, 2008 | 09:53 PM
Raven7979's Avatar
Raven7979
Well it happens all the time, hot, cold it doesnt matter. Yes i have a check engine light that has been coming on for awhile. I had a mechanic check the codes earlier this year when the light started coming on but it had no codes. Light has been coming on for about a year.
Old Nov 13, 2008 | 10:28 PM
Crazy4x4RT's Avatar
Crazy4x4RT
If the check engine light is coming on this would be the first thing to check. See what the code is. In the FAQ there is a link to show you how to read codes without a scanner. Its easy anyone can do it. https://dodgeforum.com/forum/general-tech/8717-service-engine-codes-for-obd-engines.html
You can also go to most autoparts stores and they can read them for free with a scanner. Like autozone checkers and others.
Old Nov 13, 2008 | 10:44 PM
Raven7979's Avatar
Raven7979
I get a 12 and a 32 code. Any ideas?
Old Nov 13, 2008 | 11:50 PM
JetNoise's Avatar
JetNoise
32 seems to code back to an EGR Valve...
Old Nov 14, 2008 | 08:06 AM
Raven7979's Avatar
Raven7979
How hard is that to change. Is that something I can do myself or do I need to take it in?
Old Nov 14, 2008 | 05:08 PM
fox's Avatar
fox
2 bolts, a vacuum hose, and a electrical connector and its off.
And it is located on the back of the intake manifold has a giant saucer attached to it
Old Nov 14, 2008 | 09:04 PM
Bad96_3.9's Avatar
Bad96_3.9
egr is pretty easy. was the 23 to 26 mpg on the highway or city. i got about 22 on the highway and 17 the city.
