92 dakota 4x
hello i recently purchased a 92 dakota 5.2 magnum 4x4. i just wanted to get some help on the correct steps to engage four wheel on it. i did not receive a manual for it and dont want to damage anything. thank you -sidd
2wd TO 4wd High and back
You can do at any speed. With tranny in gear. Its best to switch at some speed vs dead stop. Do a smooth shift do not hisitate.
2wd or 4wd High TO 4wd Low and back
Engine running or off Put the tranny in nutral and go 2-3mph a little speed is better then a dead stop. Shift transfercase into 4wd Low with no hisitation. Make it one smooth shift.
for the 92 the instructions say to engage 4hi the vehicle must be in motion, just pull back on the lever firmly until it engages, and the 4x4 light on the bezel of the boot will go on. I know for the at least the 96's i think you can engage it at a stop, and the stick pattern is different... i always thought the 92 was awkward w/ the diagonal...
