91-96 dak lift keys
Old Dec 13, 2008 | 07:34 PM
smokey68dart's Avatar
smokey68dart
Default 91-96 dak lift keys
anyone have a set of lift keys for the 91-96 dak that they are willing to sell or know where to get them?? all i seem to find are the ones for the 97-up so if you can help me out pm me here or email at smokey68dart@yahoo.com thanks Tracey
Old Dec 13, 2008 | 08:57 PM
Crazy4x4RT's Avatar
Crazy4x4RT
They were all over ebay. I have a site somewhere with them. If im not mistaken the 97-up will work but Im not 100% sure.
Old Dec 13, 2008 | 09:45 PM
smokey68dart
ya if the ones for the 97-up will work they are all over ebay but i cant find any that say they are for the 91-96
Old Dec 14, 2008 | 08:37 PM
95_318SLT's Avatar
95_318SLT
I ordered mine from totalperformanceonline.com a couple months ago
Old Dec 14, 2008 | 08:49 PM
95_318SLT's Avatar
95_318SLT
Here is what I got:
http://www.totalperformanceonline.co...ayout_0100.xsl
I know it says lowering kit, but what they do is reindex the hex keys 30 deg from stock, so depending on what orientation you install them they will either advance the keys 30 deg or back them off 30 deg... Basically they'll work as either lift or lowering keys.
Old Dec 14, 2008 | 11:05 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Sweet! I know I saw another site but I can't find it. At least we have one. Ill post it up in the FAQ2.
Old Dec 15, 2008 | 05:40 AM
smokey68dart
ok you wht you all think will this work i have a 91 ex cab 4x4 dak 3.9 5spd i want to put on the above torsion lift a set of blocks in back a 2in body lift a set of 33x12.5x15 on 8in with 5in back space some kind of a locker in back and not sure if they make one but an arb in the front it has 3.90 gears should be good nuff for 33's as for body a glass hood from www.buffalohoods.com a spray in liner and dont know if they can but see if they can do the dodge ram head in the liner what you all think
Old Dec 21, 2008 | 04:04 PM
Teseract's Avatar
Teseract
I'm thinking of buying an '89 4x4, will the keys from total performance online work with pre-91 Daks? I'm assuming so but I wanted to make sure. And what orientation would you install them in to get the lift? Looking at pics I'm not sure how you'd install them in a different orientation, unless they're side specific?
Old Dec 21, 2008 | 05:34 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes smokey68dart 33s will fit with the key lift and body lift. There are a few lockers for the 8.25 rear end. I belive arb does have one. I have the PowerTrax No Slip. There are a few places listed in the FAQ2, where you can buy them. The tracktion it gives is unbeliveable. The front axle is strong for stock but by thowing in a locker may cause some brakeage when in a tuff spot. A nice hood will finish the job. That one listed above would look good. There are a few more hood sites in the FAQ2.
I would think it would work for pre-91s. Here is a site where he installed the full supention lift. That kit incudes the same keys 91- up would use. See if he talks about it. http://www.walt-n-ingrid.com/modifications.html
Old Dec 21, 2008 | 07:59 PM
Teseract's Avatar
Teseract
So, just to clarify, the lift keys are identical between the first gen Dakotas and the second gen Dakotas, making all the keys the same from 1987-2004?
Thanks!
