Upgrades
Old Dec 16, 2008 | 02:19 AM
hounddogg2001's Avatar
hounddogg2001
Default Upgrades
I am wanting to do some upgrades to the engine on a '94 Dakota. Also I would like to know where to find some euro tail lights if I can for the same truck. Any suggestions for these and for a possible paint job. If you know of a website I can go to to see what paint colors would look good on the dakota I would appreciate it. Also looking for a driver side fender and door.
Old Dec 16, 2008 | 07:43 AM
OneBadKota's Avatar
OneBadKota
First off, which motor do you have?
For the Euro Lights, there's only one website I know of that sells them, but I can't think of it off hand. I know someone on here knows it.
As for the paint job, the easiest way to figure something out is to get together with someone who has Photoshop and work with it that way.
Since you're in KY, I would check local junkyards for a fender and door, I'm sure it'd be rust free. If you buy new or even used off Ebay or what not, shipping is killer, unless you find something close.
Old Dec 16, 2008 | 08:35 AM
Crazy4x4RT's Avatar
Crazy4x4RT
For the lights http://www.memoimports.com/mi/index....%2088%20-%2096 Its listed in the FAQ2 in this section. Lots of them on ebay.com Also called clear tail lights.
There is a section on this forum for people who need photoshop projects. Post up your pic and what you want done and someone can hook you up.
For motor upgrades. It depends on what you want to spend. Here a copy and paste from FAQ2.
Performance
Larger throttle body http://www.thefastman.com/Throttlebodies47.asp, Kegger mod https://dodgeforum.com/forum/2nd-gen-...e-mod-diy.html,
1.7:1 Lifters
Cams
Mopar Performance computer
High output coil + wires + cap and rotor
Spark plugs (Autolite 3923's)
Higher flow injectors
Headers
Open flowing exhaust systems
High flow cat
Lower (numaricly higher) Rear End Gears
Transmission shif kit
Machine work (deck down block, heads) (Bore out cylders).
Polish and port heads and headers
Electric cooling fan
Electric coolent pump http://www.csr-performance.com/csr_pumps.html
Under Drive pullys. (Becarefull lots are 6ribs. Mangums use 7 ribs)
Lots more....
