HVAC control unit removal...
Old Dec 18, 2008 | 12:41 AM
95dakoder's Avatar
95dakoder
Question HVAC control unit removal...
So my switch that regulates how much air is blowing broke... in the off position, and it's horribly cold in Chicago right now. I got the trim off, and removed the 2 screws that hold in the HVAC control unit, and but I can't get behind it to disconnect the wiring because of the plastic separators that separate the stereo and the air ducts from the control unit.
How do I finish removing this P.I.T.A. control unit??
Old Dec 18, 2008 | 01:44 AM
codydakota's Avatar
codydakota
It should pull out enough to get behind it and unplug it, make sure it's not catching on anything. I've never had problems getting to the back of them, granted it won't be a lot of space, but enough, especially if you have skinny fingers like me
Old Dec 18, 2008 | 09:04 AM
dbilik's Avatar
dbilik
I think you might need to get the cable that connects to the temp slider disconnected first. I am working on the same thing (in Chicago too, so I know where you are coming from) because I need to get to the heater core. That cable didn't have enough slack to allow me to pull it out. I pushed it down and off of the little knub that the end of the cable was attached to with a screwdriver. Just remember how you do it for when you need to put it back on.
I am sure there is an easier way, like disconnecting the cable from where it terminates to create more slack to work with. Especially during reassembly.
Where did you get the new control unit? I am having a hard time finding one. I am missing a few speeds on the blower when I move the switch.
Old Dec 18, 2008 | 09:05 AM
dbilik's Avatar
dbilik
Oh, and I could be wrong, but I believe I was also able to reach all of those vacuum hoses when I replaced my radio. It was a long time ago, but once I got the radio out I haveskinny arms and was able to get around back there.
Old Dec 18, 2008 | 10:55 AM
dirtball's Avatar
dirtball
Speeds on the blower are most likely the resistor unit accessable under the hood.
Old Dec 18, 2008 | 03:06 PM
dbilik's Avatar
dbilik
For me, I replaced the resistor and it didn't fix the problem. I am guessing it is the control. Having a terrible time finding a replacement for less than $180.00.
95dakoder, the switch actually physically broke off on yours right?
