what does a vss do?
Old Dec 30, 2008 | 09:59 PM
1shotjake's Avatar
1shotjake
Default what does a vss do?
alright this has been buggin me for a while... what does a vehicle speed sensor do? amongst the problems with my dak, its the only thing to throw a code for some reason.
from what I understand on the OBD1s it is responsible for the spedo, abs (maybe?) and the cruise control (which actually didn't work last i tried)
im hoping something easy to replace like this would help, but I don't wanna drop money on a sensor (again) that won't help.
on a side note, how do you guys like stackon? santa decided it was time to upgrade my tool bag to a two drawer chest.
Old Dec 31, 2008 | 08:49 PM
dodgerules86's Avatar
dodgerules86
What code are you getting?
The vehicle speed sensor does output a signal to the speedometer, the PCM, and the transmission control solenoid (automatics).
The ABS relies on its own sensors (for rear-wheel-only AND all-wheel ABS, there is a sensor located on the rear axle housing. For all-wheel ABS, there are also sensors at each front wheel hub.)
Old Dec 31, 2008 | 09:55 PM
95_318SLT's Avatar
95_318SLT
...and the transmission control solenoid (automatics).
The '95 and older have hydraulically controlled transmissions that use a throttle valve cable.
Old Dec 31, 2008 | 11:27 PM
dodgerules86
The '96s have the TV cable too.
