wheel bearing problem
I just replaced my passanger side wheel bearing and its still has that winding/grinding noise. Im not sure what it is. Also the front end is making some clunks. When i hit bumps its a lot louder than what it was before. Well the story is i got new tires and i could get my passanger front wheel off. So we melted the lugs and had to yank it off with a chain and a truck. So im sure the front end needs to be gone threw to see what got messed up. What should i start with?
Thanks guys
Jake
Thanks guys
Jake
Dang! I guess now that the damage is done, you should lift up both front wheels. Try to push and pull and on the tire. On top, sides, Bottom and see if you have any movement. If you do you could easly find what is letting it move. Then replace it. Also turn the tire and see if you can find out what is rubbing.
