TBI spacer??
Old Jan 26, 2009 | 12:08 AM
bigkat91's Avatar
bigkat91
Ok will do I just got off from work and the engine runs 200-300 rpm slower at highway speed than it did before the new plugs and wires. I was running about 2200rmp at 55mph and no its running 1900rpm at 55mph.
Old Jan 26, 2009 | 10:02 AM
bigkat91's Avatar
bigkat91
Does anybody know if the manifolds on the 91 and 92 5.2L are the same at the throttle body?
Old Jan 26, 2009 | 11:46 AM
95_318SLT's Avatar
95_318SLT
I would not consider that to be a bad thing. My truck, when the trans shifts into overdrive and the torque converter locks up, is under 1500 rpm at 55. The way my truck is geared it will go 80 mph @ 2000 rpm. It helps your gas milage out to have the engine running at a lower rpm at the same speed.
Old Jan 26, 2009 | 05:02 PM
bigkat91's Avatar
bigkat91
I was shocked that it dropped that much. I was wondering if it would.
Old Jan 26, 2009 | 06:42 PM
95_318SLT's Avatar
95_318SLT
Oooh, lol, I misinterpreted your smiley face.
Old Jan 26, 2009 | 07:02 PM
bigkat91's Avatar
bigkat91
is it expose to run that fast at 55? Cause my 02 Escape runs at about 2100rpm at 70mph. Just wondering if theressomething wrong with the tranny and or converter??
Old Jan 26, 2009 | 07:09 PM
95_318SLT's Avatar
95_318SLT
Well what tranny do you have and does it have a lockup torque converter? Also what rear end gears do you have and what size tires? Theres a lot of factors that determine what the engine rmp is at a certain speed.
Old Jan 26, 2009 | 07:26 PM
bigkat91's Avatar
bigkat91
The label under the hood said 3.9 gears A500 tranny and a lock up converter. Im running 235 75 16's tires.
Old Jan 26, 2009 | 07:37 PM
95_318SLT's Avatar
95_318SLT
The 3.90 gears will have something to do with it. My truck has 3.55 and I have 265/75R16's, but one of these days I'm gonna change them to either 3.90 or 4.11 if they make the 4.11 for both axles. You probably shouldnt worry about it. What I don't understand though is if the torque converter has a lockup clutch in it the RPMs shouldnt vary at the same speed on the highway unless it's not locking.
Old Jan 26, 2009 | 07:44 PM
bigkat91's Avatar
bigkat91
Its now running about 1900 rpm at 55mph and was running at about 2200 2300ish when I had that one cylinder not firing. I was conparing the RMP ranges with my truck and my ford escape for the same rmp in the earlier post. Would switching to 3.55 gears better my milage? I believe the pinion bearing is going out as there is a little play in the drive shaft when going from park the drive or vise versa so I will probally be getting that fixed before next winter anyhow.
