fuel filter
Old Jan 28, 2009 | 12:30 AM
bigkat91's Avatar
bigkat91
Default fuel filter
Ok guys I changed my fuel filter and when I broke opened that old one the inside was as black as 6000mile oil. Is that bad? lol
Old Jan 28, 2009 | 12:46 AM
dodgerules86's Avatar
dodgerules86
Well, I'd say no.
Should probably replace your fuel filter more often.
Old Jan 28, 2009 | 01:02 AM
bigkat91's Avatar
bigkat91
Ive only had the truck for two years and have only put about 3000 miles on it since ive got it. Ive changed the oil every three months.
Old Jan 28, 2009 | 01:12 AM
dodgerules86
Hmm... did you change the fuel filter between when you got the truck and now?
Old Jan 28, 2009 | 01:16 AM
bigkat91's Avatar
bigkat91
Nope I never thought about it until about a few months ago. I already ordered a gasket set for the TBI. I think when it comes in gonna pull the throttle body and give it a good cleaning after seeing that crud in the filter. The sad thing is, the gas that was remaining in the filter was dark.
Old Jan 28, 2009 | 09:32 AM
DukeSupes's Avatar
DukeSupes
Good call on the TBI gasket. I noticed a stain on the intake from where mine has been leaking. I will do the same and see if I can clean it up some. Maybe this will also increase gas mileage some! I am tired of seeing 14 mpg.
Old Jan 28, 2009 | 09:56 AM
bigkat91's Avatar
bigkat91
Im tired of seeing 12mpg no matter how I drive it. I also ordered a shift kit and pumkin gaskets at to change the fluid in both axles to synthetic oil.
Old Jan 28, 2009 | 06:24 PM
bigkat91's Avatar
bigkat91
UPDATE.
Since replace the fuel filter last night the truck idles smoother and when I kick off the gas it doesnt buck and shudder as I did before.
