94 5.2l Heat Selector Cable problem...
Old Jan 31, 2009 | 07:38 PM
breakfastboy's Avatar
breakfastboy
Default 94 5.2l Heat Selector Cable problem...
My heat selector cable has come out of place so I can't change from hot to cold, wondering if someone could direct me on how it is supposed to be connected to the lever?! My blower and hvac all works great, I just can't get the selector set up to move the mixer door.. Cheers.
Old Feb 1, 2009 | 12:08 PM
extreme93's Avatar
extreme93
Did it come loose at the blend door in the air box or the at the switch??
Old Feb 1, 2009 | 05:30 PM
breakfastboy
at the switch, the blend door end seems to be fine.
Old Feb 3, 2009 | 07:52 AM
breakfastboy
I just need to know where the end of the cable hooks onto. There is an eye on the cable and I know that attaches to the lever, it just doesn't seem to want to stay on any way I've tried, does anyone have a pic of the top of the temperature control unit with the cable installed??
Old Feb 3, 2009 | 10:46 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Im sure you can find a good pic of one in the servace manuals or even the part manuals we have posted in the FAQ in this section.
Old Feb 3, 2009 | 07:23 PM
breakfastboy
Thanks for the suggestions Crazy, I did check the Haynes manual along with an on-line manual and the FAQ's, none showed a picture of the unit assembled, or gave instructions on that specific task. For some reason this simple job is quite a headache! I know it's easy, I just can't seem to find the answer. I changed my water pump and bypass hose last week and that was a joke compared to this!! lol
