beafing up my 318
Old Feb 4, 2009 | 09:44 PM
dakotaredneck's Avatar
dakotaredneck
Default beafing up my 318
i got a 1992 dodge dakota 5.2l 318 and im lookin for some good ideas on more torq and horse power already figuerd on headders and k an n air cleaner and throtel body tower
Old Feb 5, 2009 | 02:31 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Lots you can do. It depends on what you want to spend. This is a copy and paste from the FAQ2. For where to get these parts and other info check out the FAQ2 in this section.
Performance
Larger throttle body http://www.thefastman.com/Throttlebodies47.asp, Kegger mod https://dodgeforum.com/forum/2nd-gen-...e-mod-diy.html,
1.7:1 Lifters
Cams
Mopar Performance computer
High output coil + wires + cap and rotor
Spark plugs (Autolite 3923's)
Higher flow injectors
Headers (v6 https://dodgeforum.com/forum/1st-gen-...9-headers.html)
Open flowing exhaust systems
High flow cat
Lower (numaricly higher) Rear End Gears
Transmission shif kit
Machine work (deck down block, heads) (Bore out cylders).
Polish and port heads and headers
Electric cooling fan
Electric coolent pump http://www.csr-performance.com/csr_pumps.html
Under Drive pullys. (Becarefull lots are 6ribs. Mangums use 7 ribs)
Lots more....
