Steerin Knuckle/Ball Joints
I'm replacing the steering knuckle and ball joints on my 95 Dakota 4x4. I cannot for the life of me get the old ball joints separated from the knuckle though. So far all I've tried is a pickle fork and BFH, and they would not budge. Is there anything I can take off to make the job a bit easier? Thanks
Matt Poker
Matt Poker
LOL! I delt with this today and last week. The pickle fork with my 18lb slug hammer it worked on one side but not the other. I had to get my small jack and push up with the jack on the ball joint stud. I belive a wider fork would have worked. OEM has a ball joint stud remover which is a threaded rod that jams it upwords.
I got the knuckle off today with the jack under the stud and hammer method. The upper ball joint has been replaced, but I can't figure out the lower. Do I have to press it through the bottom of the control arm, or the top? Thanks for all the help everyone!
Matt Poker
Matt Poker
