motor swap help please
Old Feb 16, 2009 | 03:06 AM
smokey68dart's Avatar
smokey68dart
Default motor swap help please
ok i looked thru the faq1&2 but didnt find what i needed all i can find is for the magnum motors
what i have is a 91 dakota V6 4x4 5spd trans will be a ax15 from a 93 4x4 dakota my motor is a V6 and i want to swap in a 5.2 pre magnum i found a low mile 5.2 from a 90 dodge van it is fuel injected also will the wiring from the 3.9 plug into all the sensors on the 5.2 will the tr. body plug into the 3.9 wiring and i have the ext manifolds from a 92 5.2 that im going to use on this what all am i missing here what do i need to look out for please help i want to get everything together b4 i start this thanks smokey
Old Feb 17, 2009 | 03:05 AM
Crazy4x4RT's Avatar
Crazy4x4RT
I'm not 100% sure but I doubt that the wires will plug in easy. If you have access to the 318 right now go check every connector. You should get everything from the Engine, intake, wires, computer. I think you will have to swap out the wiring harness as well as the computer. The exhaust manifold may fit. I wish i could help you more. Maybe someone else will have some Ideas!
