Transmission parts
Old Feb 23, 2009 | 09:43 PM
mopower65's Avatar
mopower65
Default Transmission parts
I have a 93 dakota 4x4 with a 3.9 and an automatic. I bought it a couple of years ago and have done a bit of work to it including rebuilding the transmission. When I did the transmission, the kickdown lever in the transmission was a bit rusty where it was exposed to the weather and dirt. I couldn't find a source for the part back then, so I tried to clean it up and re-use it. I figured that if I could find another one, I would be able to fix it without too much effort. Since I put the truck together, it has been leaking. I am getting a bit tired worrying about the fluid level. I know from looking at this forum how fragile these transmissions are.
Anyway, I am looking for suggestions on where I should look for this part. I have tried to do a Google search and came up with nothing.
Any help would be greatly appreciated.
Old Feb 24, 2009 | 12:24 AM
Crazy4x4RT's Avatar
Crazy4x4RT
The best place will be dealer or these sites.
http://www.moparpartsamerica.com/par...?siteid=214583
https://www.dodgeparts.com/oe_parts_...e2cf8fa4e8846c
You can get the part number off of the part manuals we have located in the FAQ (The parts manual is off-line for now, you will have to go to dealer for the part number). You said it is leaking. I would replace the seals at that location too.
