need help with 94 dakota 4x4 trans
Old Mar 15, 2009 | 01:08 PM
goaatman's Avatar
goaatman
Default need help with 94 dakota 4x4 trans
i have a 94 dakota with v6 4x4 with auto trans and need a trans can anyone tell me if a 4x4 auto trans out of a 95 dakota with a v8 is the same or if it will work behind the v6
thanks
Old Mar 15, 2009 | 01:47 PM
95_318SLT's Avatar
95_318SLT
A '94 is a 1st gen dakota, so this thread should be moved...
But to answer your question, yes the transmissions are compatible. You'll want to use the flex plate for the v6, but the transmission will bolt up. A 46rh is basically a "beefed up" 42rh, and the engine blocks are identical except for the extra 2 cylinders.
Old Mar 15, 2009 | 02:01 PM
dodgerules86's Avatar
dodgerules86
Lol, no, the V6 has 2 missing cylinders.
Old Mar 15, 2009 | 02:06 PM
95_318SLT's Avatar
95_318SLT
Lol, I meant the v8 block is identical to the v6 but with 2 extra cylinders, but whichever way you try to word it you know what I meant.
Old Mar 15, 2009 | 02:16 PM
goaatman's Avatar
goaatman
how do i move it
Old Mar 15, 2009 | 02:25 PM
95_318SLT's Avatar
95_318SLT
Originally Posted by goaatman
how do i move it
I'm not sure what you mean.
Old Mar 15, 2009 | 02:28 PM
dodgerules86
He may of meant "How do I move it to the right section?"
In which case, I just did.
