Engine shuts down
Old Mar 21, 2009 | 12:37 PM
RisingMoon's Avatar
RisingMoon
Default Engine shuts down
My 96 Dakota Sport 2.5 MFI starts, runs for short while then shuts off like it was turned off. I have changed the fuel pump and filter, sealed vacuum lines, crank sensor, timing set. pickup plate, coil, spark plugs and wires, and replaced o rings on injectors. I have checked the fuel pressure and throttle body.
I'm looking for any suggestions and cures to the problem.
Old Mar 21, 2009 | 01:17 PM
dhvaughan's Avatar
dhvaughan
when it shuts off. does it start back up immediately, or does it take awhile ?
and if it doesn't start back up immediately - do you have fire at the spark plugs ? this identifies if its electrical or fuel...
Old Mar 21, 2009 | 01:41 PM
RockGuardedDak's Avatar
RockGuardedDak
does it cough and sputter before it stalls or does it just up and shut off?
Old Mar 21, 2009 | 09:18 PM
dbilik's Avatar
dbilik
Read through the FAQ, there is a picture of the notorious "splice" that you should check under the hood. Also check your relays after you check the splice.
Old Mar 21, 2009 | 11:14 PM
RisingMoon's Avatar
RisingMoon
I have to shut the key off for a short while, then it runs for a shorter period. The longer I wait the longer it runs.
Old Mar 21, 2009 | 11:15 PM
RisingMoon's Avatar
RisingMoon
It just shuts down.
Old Mar 22, 2009 | 01:55 AM
dbilik's Avatar
dbilik
Same problem I had as my splice was failing. The problem changed slightly from turning over and running for a short time to eventually turning over and never running unless I poured gasoline directly into the intake.
