How to check vaccum on cruise control?
Old Apr 1, 2009 | 09:18 AM
ba_50's Avatar
ba_50
Default How to check vaccum on cruise control?
An auto parts service man listened for a hissing sound and found none. Is there a better way on a '94 6 cylinder model. Thanks.
Old Apr 2, 2009 | 12:20 AM
stesul411's Avatar
stesul411
Trick I use for checking for vac leaks is to get a can of carb/tb spray cleaner and spray the suspected vac hose, if the engine starts to run rough it's sucking in the cleaner. I have also done the same thing with a unlit propane torch, if the idle picks up, you found it.
Old Apr 2, 2009 | 12:56 AM
RockGuardedDak's Avatar
RockGuardedDak
thats a cool trick! i woulda never thought of it. im gunna use that to find leaks from now on.
Old Apr 2, 2009 | 02:14 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Ya it works good on the intake manifold to check to leaks.
