please help! will a short bed drive tran work with a ext cab
Old Apr 8, 2009 | 05:43 PM
methodman1992's Avatar
methodman1992
Default please help! will a short bed drive tran work with a ext cab
hi! i have a 93 dakota with a back seat! and am looking at a 95 without a back seat for a parts truck. will it work? am hoping to use the rearend to trans! they both have a 3.9 magnum in them and are both 2wd please need a answer asap! Thanks
Old Apr 8, 2009 | 06:16 PM
98daksport's Avatar
98daksport
should work, no reason it shouldn't
Old Apr 8, 2009 | 06:35 PM
RockGuardedDak's Avatar
RockGuardedDak
the only thing you wont be able to use off the '95 is the drive shaft
Old Apr 8, 2009 | 08:33 PM
95_318SLT's Avatar
95_318SLT
Agreed. When I did my tranny swap the tranny came out of a reg cab and I have an extended cab, and the trannys were different lengths so I ended up having to have a driveshaft custom made.
You shouldn't need the driveshaft though, you'd be hard pressed to break a driveshaft so your's will still work unless your putting a tranny in that is a different length than your current one.
