scary problem
Old Apr 11, 2009 | 05:56 PM
dakota26's Avatar
dakota26
Default scary problem
hello my 96 dakota in the rear on the right side the brakes are full of grese what is the cause of this help help
Old Apr 11, 2009 | 06:30 PM
codydakota's Avatar
codydakota
My best guess is it's coming from the axle, but that's without seeing it first hand
Old Apr 12, 2009 | 12:19 AM
RockGuardedDak's Avatar
RockGuardedDak
axle seals or the wheel cylinder
Old Apr 12, 2009 | 04:05 AM
95_318SLT's Avatar
95_318SLT
If the "grease" looks like gear oil, you have a bad axle seal and its leaking out from the differential/axle housing. If it is actual grease (as in the solid, not the liquid) then it could be the wheel cylinder, but they don't hold all that much grease.
Old Apr 12, 2009 | 05:38 AM
denice25's Avatar
denice25
better check your axle seals....
Old Apr 15, 2009 | 09:18 AM
02WhiteRam's Avatar
02WhiteRam
I would also check your wheels cylinders (if you have drum brakes) those are pretty goog for leaking over time.
Old Apr 15, 2009 | 11:36 AM
95_318SLT's Avatar
95_318SLT
I doubt it's the wheel cylinder unless your loosing brake fluid, cause if they start to fail they will leak brake fluid as well as any grease that may be in them.
Old Apr 15, 2009 | 02:13 PM
RockGuardedDak
agreed, but at the same time how do we know its not leaking brake fluid? dakota26, is it leaking brake fluid too? if so, then its the wheel cylinder. if not, then its the axle seals
Old Apr 15, 2009 | 03:21 PM
95_318SLT's Avatar
95_318SLT
Lol, there was an indirect question in there. In a way I was asking if it was leaking brake fluid while suggesting that if its not then its not the wheel cylinder
Old Apr 16, 2009 | 02:20 PM
dakota26's Avatar
dakota26
Thumbs up
hello guys thx 4 the help i got it fixed it was the seal all good now and sorry 4 not geting back to you sonner
