Fuel pump going out?
Old May 14, 2009 | 12:50 AM
94tbkota's Avatar
94tbkota
Default Fuel pump going out?
Ok so the fuel pump is CRAZY loud and always makes like a buzzz......buzzzz......buzzzz. its not a continuous noise but broke up and also the gauge is way off and its died a few times. Is the noise normal and also well what do yall. think man i sure do ask alot of questions just keepin yall all busy with something to do.
Old May 14, 2009 | 02:34 AM
Crazy4x4RT's Avatar
Crazy4x4RT
It may be. Change it out before it dies on you and leaves you stranded.
Old May 14, 2009 | 09:46 AM
dbilik's Avatar
dbilik
When I changed mine I took the bed off instead of messing with the straps and dropping the tank. I think the bed is only held on by 8 bolts. Up to you though how you approach it.
Old May 14, 2009 | 10:44 AM
Bump's Avatar
Bump
well hell... if your going to do it that way, you might as well have a body lift on hand! haha.
I dropped mine from underneath. Not that bad, but Id recommmend low to no fuel first!
Full tank is damn heavy!
