Weird Stall
Old May 29, 2009 | 12:58 AM
ZackN920's Avatar
ZackN920
Though what is the O2 senser supposed to do, even for a fuel injection system?
I know its supposed to test the oxygen but what more does it do for the engine
Old May 29, 2009 | 01:12 AM
95_318SLT's Avatar
95_318SLT
The o2 sensor on an EFI engine monitors the oxygen levels in the gas. I could try to explain it in my own words, but for a lack of confusion, here is a description from the '95 FSM...
OXYGEN (O2S) SENSOR—PCM INPUT
The O2S sensor is located in the exhaust down pipe
(Fig. 10). It provides an input voltage to the powertrain
control module (PCM) relating the oxygen content
of the exhaust gas. The PCM uses this
information to fine tune the air-fuel ratio by adjusting
injector pulse width.
The O2S sensor produces voltages from 0 to 1 volt.
This voltage will depend upon the oxygen content of
the exhaust gas in the exhaust manifold. When a
large amount of oxygen is present (caused by a lean
air-fuel mixture), the sensor produces a low voltage.
When there is a lesser amount present (rich air-fuel
mixture) it produces a higher voltage. By monitoring
the oxygen content and converting it to electrical
voltage, the sensor acts as a rich-lean switch.
The oxygen sensor is equipped with a heating element
that keeps the sensor at proper operating temperature
during all operating modes. Maintaining
correct sensor temperature at all times allows the
system to enter into closed loop operation sooner.
In Closed Loop operation, the powertrain control
module (PCM) monitors the O2S sensor input (along
with other inputs). It then adjusts the injector pulse
width accordingly. During Open Loop operation, the
PCM ignores the O2S sensor input and adjusts injector
pulse width to a preprogrammed value (based on
other sensor inputs).
Old May 29, 2009 | 01:27 AM
ZackN920's Avatar
ZackN920
Huh, but that talks about it being in the exaust and theres an oxygen senser hooked right to the air intake
ill put a picture up
Now i think that grey/silver cap on the intake is where the sensers hooked up and theres a tube that goes to it and wires that come out the other side and ive seen something written and a picture of one in my trucks manuel but isnt that the O2 senser or not?
Old May 29, 2009 | 01:33 AM
dbilik's Avatar
dbilik
95_318SLT was referencing a fuel injected truck and how the mixture is control by the o2 snesor and the computer.
Old May 29, 2009 | 01:37 AM
ZackN920's Avatar
ZackN920
Yes but that was because i wanted to know how it worked for fuel inj. and carb but its still unknown somewhat about the carb's O2 senser which i read that the truck had
Old May 29, 2009 | 01:44 AM
95_318SLT's Avatar
95_318SLT
That is not an o2 sensor. That is something called a Thermostatic air cleaner. It's job is to draw hot air to the carb (usually gets heated by the exhaust manifold) while the engine is cold.
Old May 29, 2009 | 01:49 AM
ZackN920's Avatar
ZackN920
Im talkin about whats hooked up to the cap on it which has a small thin tube that leads to some cilindered shaped 'thing' that then has wires(cant be seen in photo) coming out the other side
And i do know though that it has one at least according to the manual
Old May 29, 2009 | 01:55 AM
95_318SLT's Avatar
95_318SLT
I'm not even going to pretend I know exactly how those electronically controlled carbs work, so I'm going to direct you to this article...
http://www.allpar.com/fix/fixcarb.html
Old May 29, 2009 | 01:59 AM
ZackN920's Avatar
ZackN920
That will probably help but ill check it out tomorow, thanks for the help so far man!
Old May 29, 2009 | 02:04 AM
95_318SLT's Avatar
95_318SLT
If I was right about it being a tuning issue, here is an article on how to tune it...
http://www.allpar.com/fix/carb-tuning.html
and there are many other good articles on this page....
I hope you find your answer in there somewhere! If so, let us know.
