Replacement oil pan
Old May 30, 2009 | 12:45 PM
dbilik's Avatar
dbilik
Default Replacement oil pan
The oil pan on my new engine was stored bad and got dented before I bought it. Would you replace it for this? It is only about 3/16 deformed, it was set on angle iron instead of block. Clearance won't be an issue and I see no cracks in it, but wanted a second or third opinions. See photos below. And if you would replace it, what replacements would you recommend? Something a little heavier duty?
You can see where the little 1 inch strip of paint was knocked off from the inside of the oil pan.
Here it is from the outside.
I am personally leaning towards just leaving it and not doing anything.
Old May 30, 2009 | 02:31 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Your pictures didn't come up. Here they are.
It doesn't look bad. As long as there are no creases in it It should be okay.
