EGR valve removal
Old Jun 2, 2009 | 03:32 PM
murdered93'kota's Avatar
murdered93'kota
Question EGR valve removal
i have a 93 dak w/ a 318/automatic and i wanted to pull the egr valve but i dont know how it will effect the vehicle performance ex. gas mileage/power/overall running condition. if you can help let me know plz.
Old Jun 2, 2009 | 07:17 PM
Crazy4x4RT's Avatar
Crazy4x4RT
It will in theory will hurt performance and gas mileage. I do have mine off due to the 5.9 swap. But I do wish I had mine on. For the purpose of having the best gas mileage possible. The EGR stands for Exhaust Gas Recirculation. It recirculates unburned gases and send it back into the engine to burn it. So you will save on gas. If everything is working properly it is best to leave it. No performance will be gained by taking it off. It does not hurt performance in anyway.
Old Jun 3, 2009 | 12:59 AM
1shotjake's Avatar
1shotjake
doesn't it also lower the activation energy of the fuel/air mix in the cylinder requiring lower temperatures to combust?
What I was wondering, is if the computer requires the EGR for the engine to function properly in that It takes into account the EGR when controlling the mix and timing?
Old Jun 3, 2009 | 12:25 PM
murdered93'kota
resistor across the plug
Old Jun 3, 2009 | 10:58 PM
Hahns5.2's Avatar
Hahns5.2
If your EGR works, you aren't gaining anything by removing it. Mine is only removed because I'm using a non EGR M1 intake manifold.
