please help!
Old Jun 8, 2009 | 02:39 PM
brotherjayme's Avatar
brotherjayme
Angry please help!
just baught a 94 dakota but have two problems!
first, the brake lights don't work even though the turn signals do. i changed the bulbs and the brake light switch but still no luck!
Second, i figured out the day after i baught it that the transmision fluid is leaking from what seems to be the trans pan. i replaced the seal and filter yesterday and everything seemed fine until i looked under it this morning and theres a puddle of fluid in the drive way! where do i look next?
Old Jun 8, 2009 | 05:06 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Have you check fuses? Did you check to see if your getting power after the switch? Maybe a wire problem. Check all wires and connectors.
As for the transmission leak you may want to look around before you post something. Here is one someone asked yesterday. A few posts below this one. https://dodgeforum.com/forum/1st-gen...nny-fluid.html
