Urgent please help me!!!
Ok so yesterday my truck shut off and would crank back on. It would spin over but no spark. But the thing i noticed was the cel wasnt comming on not even if i cycled the key so almost like the computer stopped workin. But today after it sat all night i went out and it cranked right up. So please help me......... And i didnt search because im havin to use my ipod and it wont let me search. So if you can it would be easier to text me at #8135628776
remote starter?
if yes first suspect then start with fuses in cab and PDC Fuse D&E BUT CK THEM ALL then ASD RELAY.... Iwill ck further is this v6 v8 ? sorry text msging - not going to happen |
Ok no remote starter all stock 94 v6 only thing with fuses is i went out a little while ago and drove it for like 20 minutes so i dont understand
I agree with the ASD relay. This problem has been popping up on this forum at least once a week recently. Check the power splice to the ASD relay and Fuel Pump relay and clean up the connection. The write up on it is in FAQs.
What do i gotta do to get to the connections are you talkin inside the fuse box under the hood because i read somewhere about there wires spliced together but didnt see them its drivin me crazy cuz it did it yesterday then started and drove fine then i came outside to do somethin and it wouldnt start then i just got back and it cranked fine. I just think it is weired because i can tell when its not gonna start because when i turned the key the check engine light just doesnt cycle at all. Thanks for the help though guys.
1 Attachment(s)
I think the splice they're talking about is the one underneath the PDC under the hood. The are a few bolts that hold the PDC onto the fender. Unbolt it and lift it up. You will see a thick bundle of wires that run below it. There is where you will find the infamous splice that goes bad. You may have to remove some of the tape that bundles the wires but it's there, and for gods sake please be sure that the battery is disconnected before you start this venture. Hope this picture helps, this is what I found when my '95 wouldn't start.
This really sucks man...lol
