89 Dakota rear differential abs sensor
Old Jul 1, 2009 | 02:33 PM
aliengenius's Avatar
aliengenius
Angry 89 Dakota rear differential abs sensor
My father in law has a 1989 Dakota 3.9L and his ABS and Brake lights are on and his Speedometer doesn’t work. I did some reading and found out that it is the rear differential abs/speed sensor. He got a new one and when I went to put it in I noticed that the plug leading out of it was corroded and broken, and when I followed that wire I also noticed that the pigtail that it connected to, was also corroded. The truck has well over 250,000 miles on it but he loves it and just put a whole mess of new parts in it. but anyway he went to the dealership and asked about the wire and the pigtail and they said it was discontinued, and no auto parts store carries it, and I have looked all over online and could not find anything except what could be the pigtail, but I would still need the wire that goes from the sensor to that pigtail. Does anyone have any idea what the name of this wire is, or where I can get one.
Old Jul 1, 2009 | 04:26 PM
95_318SLT's Avatar
95_318SLT
Do you have pictures?
When I did my axle swap to a 2001 corporate 9.25 inch, I thought the 6 year newer ABS sensor would give me problems, but my ABS system talks to it fine after I spliced the old connector onto the new sensor leads. Honestly, I don't think it will be a big deal to fix from my experience messing with that sensor, but I'm having trouble picturing what your trying to say.
Old Jul 1, 2009 | 07:13 PM
skyshark186's Avatar
skyshark186
Ive got a parts truck, and wont be using that piece. If you can get me a picture of what exactly you need I can ship it to you for a small fee. Probably easier than searching the net for hours.
Old Jul 2, 2009 | 08:07 AM
aliengenius
I will try and get pictures up by the end of the day.
When i get the pictures up and if i can splice it, that would be good, but if not then i will most likely take sksyhark186 up on the offer
Old Jul 2, 2009 | 08:53 PM
aliengenius
Here are the pictures that i promised you, any solutions to the problem would be greatly appreciated. i need these 2 pieces because as you can tell from the pictures they are both broken
Thank you in advance for the help
The wire from the sensor (connector on left and also broken) to the pigtail (connector on right)
Close up of connector to pigtail on chassis
Close up of connector to the abs/speed sensor on the differential (what its suppose to look like)
(2 above) pictures of the pigtail that the first wire connects into
Old Jul 2, 2009 | 10:51 PM
95_318SLT's Avatar
95_318SLT
It looks to me like the left pin is broken off in the 2nd picture? If thats the case, you can either get a new connector from a donor truck or don't use the connectors and solder or crimp the wires together.
Old Jul 6, 2009 | 02:35 PM
aliengenius
i can solder them, im not sure if that wire (picture 1) has anything electrical in it, such as a risistor or something. but yes i can solder it and also in the connector in picture 3 is broken, so thats the other problem. if anyone has that wire, (i dont need the pigtail any more (last 2 picture)) let me know a price and maybe we can work something out, i live in east stroudsburg PA 18302
