fan clutch - electric fan
Old Jul 10, 2009 | 02:18 PM
DukeSupes's Avatar
DukeSupes
Default fan clutch - electric fan
Does anybody have a recommendation on an electric fan? I believe the fan clutch is going out on my truck and would like to look at all options for replacement. Especially if they will get me more HP and better mileage.
Old Jul 10, 2009 | 03:20 PM
ZackN920's Avatar
ZackN920
Im just wondering but how does the fan clutch go bad and how do you know? overheating as in the clutch isnt grabbing and the fan slips or the clutch never lets go of the fan and it then runs as fast as the engine the whole time?
Old Jul 10, 2009 | 03:45 PM
DukeSupes's Avatar
DukeSupes
How does anything go bad? With lots of use or misuse.
I suspect its going out because the truck isnt cooling as it should and when it does start to over heat the truck sounds like a semi in low gear pulling a load. I am going to do further testing this weekend.
I just want to know what options I have should this turn into what I think it will. Mainly, if I do want to go with an electric fan I want to know how much time it will take to order, how much it will cost and the ease of modification.
Old Jul 10, 2009 | 03:56 PM
ZackN920's Avatar
ZackN920
Well i gess my first question was stupid but is it possible to just weld the fan or directly attach it to the shaft and just say F*ck the clutch
Old Jul 10, 2009 | 04:30 PM
DukeSupes's Avatar
DukeSupes
I am not sure. Thats an interesting idea though. If it wouldnt be sucking on my HP the whole time I would be more proactive about investigating it.
From what it looks like I can get an electric fan for the same price as a new clutch but it looks as though I would also need to purchase a wiring harness that would almost double the price.
Anyone here already put an electic fan on their truck??
Old Jul 10, 2009 | 04:54 PM
Crazy4x4RT's Avatar
Crazy4x4RT
There are a few of us who has put them on. Here is a quick write up I have in the FAQ2.
Electric Fans
There is not a direct bolt in kit. The best choices are to Get a dual fan unit from a Ford Contour/Mercury Mystique. or the dual fan from a 98-03 Intrepid. I think you can also use a dual fan unit out of an early/mid 90s Camaro. You may need to make custom mounts. You can also go to most parts stores or www.summitracing.com and buy universal fans, check www.ebay.com too.
Old Jul 11, 2009 | 01:09 PM
Blue 12's Avatar
Blue 12
i have a set of aftermarket electric fans on a toggle switch.
some vehicles dont have the clutch, and the fan spins the same as the motor all the time. my buddys chev was like that untill i put a set of electric fans on it after we did his body lift
Old Jul 11, 2009 | 01:31 PM
skyshark186's Avatar
skyshark186
How many cfm are you guys running? Summit has single fans that can push over 3000.
Just ordered my body lift so Ill need fans soon. By the way amazon has the body lifts for 84 bucks with free shipping.
Old Jul 11, 2009 | 01:37 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I'm not sure what my fans are rated at. But they are 14in and 15in. They cool the truck great!
Old Jul 11, 2009 | 07:06 PM
hokunahooikaika's Avatar
hokunahooikaika
does anyone know of a do it yourself guide for installing the fan and electronics?
