A/C not working :(
Old Aug 9, 2009 | 03:39 AM
viper1891's Avatar
viper1891
Default A/C not working :(
hi everyone! i have a 1988 dodge dakota sport 3.9 and my a/c is not working at all. i checked the fuse and it was good but a/c's really get me thinking. it doesnt need to be recharged or anything. it just doesnt turn on. the blowers work also. what could it be? thanks everyone
Old Aug 9, 2009 | 04:15 AM
Coadster's Avatar
Coadster
If it doesn't 'click' on, it is more than likely the compressor.
Old Aug 9, 2009 | 07:27 AM
grswat's Avatar
grswat
How do you know it doesn't need to be recharged? If you can locate the low pressure switch you can jump a wire across it and the compressor clutch should engage. If it does and you get cold air then you either need more freon or a new switch. If it doesn't then it could be really low on freon. I'm not the most knowledgeable on a/c but usually systems are just low.
Old Aug 9, 2009 | 08:02 AM
Crazy4x4RT's Avatar
Crazy4x4RT
The best way to check if it needs to recharged is take it to a shop. Even brakemasters or most jiffy lubes will check it.
Old Aug 9, 2009 | 09:42 PM
ZackN920's Avatar
ZackN920
Also make sure your compresser is actually running, Hopefully i dont hijack your thread but,
I also found out a while back my A/C actually still cools as long as its ran for around 2-5 minutes and is like in the high 70s or above but only cools like 5 degrees and i cant refill it but when i do turn it on i sometimes hear a hiss inside the cab, is it leaking through the ventalation system or do they normaly do that when you first turn it on?
Old Aug 15, 2009 | 08:43 PM
viper1891's Avatar
viper1891
where is the low pressure switch? the clutch is not engaging so it is my comprsser
Old Aug 16, 2009 | 01:16 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Not sure on the 88 but on the 92-up it is on the firewall, passenger side. Just follow the hoses. You can check the FAQ for the service manual to see for sure
