exhaust question
Old Aug 28, 2009 | 03:04 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Originally Posted by ace_
it gos back to the motor
I don't think a mount would go to the engine. Also I worked on plenty of 80's junk! I have replaced a few cats on 80's junk too. I hate 80's style emissions!
Old Aug 28, 2009 | 03:08 AM
95_318SLT's Avatar
95_318SLT
Ooooooooh... I was confused. I have no idea what his cat looks like, I thought he was talking about the things sticking out of the cat in the picture he put up, which are just mounts. To the OP... if your cat has something else, then yes, you'll need to duplicate it somehow.
Old Aug 28, 2009 | 03:14 AM
ace_'s Avatar
ace_
well if it goes to smog i can cut it off my smog isint even hooked up and on my cat theres only 1 rod coming out of it and its not capped of it goes back towards the motor
Old Aug 28, 2009 | 03:21 AM
Crazy4x4RT's Avatar
Crazy4x4RT
It is not a mount in the pic. It is the smog pump pipe. Here is a quick pic.
As for your question if you can cut it off, like said before if you state law says you need to have your vehicle inspected or emission testing done then NO you can not cut it. You will need it to look like it is still stock.
Old Aug 28, 2009 | 03:26 AM
ace_'s Avatar
ace_
ok yeah that makes a lot more sence but in MO you have to have a cat on it if it was origanlly released with one but not the smog mines on the truck but therse no belt to run it and if it did my truck passes almost everytime my cousin inspects it for me and he checks the basic needs
Old Aug 28, 2009 | 03:33 AM
ace_'s Avatar
ace_
and if it helps ill go take some pictures when i can it hopefully will limit confusions
Old Aug 28, 2009 | 03:40 AM
95_318SLT's Avatar
95_318SLT
No, I'm not confused anymore... just too young to know the differences in the '80s emissions equipment. I understand now. If you can get it "inspected" by someone you know will pass it, then don't worry about it. But if you still want it to "look" right, weld in your pipe, bending that tube out of the way inside if need be. You already said the smog pump is unhooked, so having that tube go nowhere won't hurt anything.
Old Aug 28, 2009 | 03:29 PM
ace_'s Avatar
ace_
Attachment 5477
Attachment 5478
Attachment 5479
ok but for furture reference
Old Aug 31, 2009 | 07:01 PM
94 mark3's Avatar
94 mark3
my 300zx's cats were like that too. but i replaced them with test pipes
if your cousin can get your truck inspected, cut the cat off, and weld in a new peice of pipe
Old Aug 31, 2009 | 08:20 PM
ZackN920's Avatar
ZackN920
I want to hear how this sounds after your done, im just curious to see if a LA 3.9 V6 would sound good on glasspacks or not
