90 dakota idle problem
Old Aug 29, 2009 | 09:40 PM
dakota_freak1989's Avatar
dakota_freak1989
Default 90 dakota idle problem
hello im having a issue with my Dakota sometimes when i start the truck it'll stumble and die at idle but other times it'll start and run fine i cannot figure out whats doing it any help would be apritiated it runs fine cold sometimes and other times itll run fine warm but but others itll act like its not getting fuel but it is sometimes while driving when i change gears it'll die and ill have to bump start it while still coasting its getting fuel and spark and everything works i just cant figure out whats making it do this please any help would be appreciated thanks in advance
Old Aug 29, 2009 | 10:13 PM
95_318SLT's Avatar
95_318SLT
What engine?
I would start by checking the IAC and MAP sensors and make sure there are no vacuum leaks. Also check the fuel pressure. Just cause the pumps on doesn't mean it's putting out 100%.
Old Aug 29, 2009 | 11:11 PM
dakota_freak1989
it has the 3.9l v6 where are the map and iac sensors? and would it make it do this if it had the egr valve disabled ? i tinkerd around with it a few minutes ago and got it running but i dont know if it was just because it was sitting for a few hours or if i actually fixed it i do not know all i did was play around with vaccume hoses and the fuel filter could a clogged fuel filter cause these problems?? its one thing im suspecting but dont get my check for a week or so but once i do i can replace anything cus money wont be an issue i just want to make my truck run excellent and be dependeble thanks for your input
Old Sep 25, 2009 | 01:29 PM
whitet's Avatar
whitet
I can almost guaranty that your problem is the IAC motor. This is located on the drivers front side of the throttle body. It looks kind of like an actuator and if you look has an adjustable screw pushing on the throttle arm. These things are crappy at best and parts stores are extremely proud of them . I think the last one I bought was $110 or something like that. It lasted about 4 months. You can manually put power to the plug and see if it works or not. This is what makes the brief buzzing noise after you turn off your motor. If you can still hear this noise, have someone shut down the engine while you watch the actuator arm. If it moves, its obviously ok, if it doesnt, something is broken inside. Hope this helps.
Old Sep 25, 2009 | 04:43 PM
kahanabob's Avatar
kahanabob
Originally Posted by dakota_freak1989
could a clogged fuel filter cause these problems?? thanks for your input
I would change it, is under the truck, drivers side, along the frame.
Old Sep 25, 2009 | 10:08 PM
93dakotafamilyman's Avatar
93dakotafamilyman
man my truck was doing the same thing before the fuel pump went out on a nice warm day i started with the filter cause it was a cheap start then checked fuel pressure just got nothing but tiny dribbles...changed the pump and its working like a champ now
Old Sep 29, 2009 | 04:49 PM
Lakota's Avatar
Lakota
my truck has the same problem. its a 91 with the 5.2L V8 motor, i checked the vacum lines and will be checking the timing tonight. any other suggestions?
