Ball joint woes...
Old Sep 4, 2009 | 06:39 PM
Littlejon126's Avatar
Littlejon126
Default Ball joint woes...
So, trying to do the ball joints on my 95 Dakota 4x2 3.9L (The Cursed Truck) and for the life of me, I cannot remove the uppers. After 6 hours, we got NOTHING. Is there some trick to removing them??
Also, since removal has been such a pain, I can only imagine install. Are there any tricks to this as well??
Thanks in advance y'all!
Old Sep 4, 2009 | 08:10 PM
dodgerules86's Avatar
dodgerules86
How are you trying to remove them?
Are you trying to press them out?
The upper ball joints are indeed threaded into the control arm. It is a special 2-1/8" (two and one-eighth inch) socket you will need.
Chrysler special part number C-3561
I bought a socket from SJ Discount tools (http://www.sjdiscounttools.com/sk84689.html)
NOTE: This is a 3/4" drive socket, so this is larger than the ratchets/breaker bars most people have.
Now, assuming you have the correct tools, all I can say is either get your hands on a big honker air gun, or, get a cheater pipe (the pipe I fit over my 3/4" breaker bar was probably 5 feet long!)
The threads on these are the normal lefty loosey, righty tighety.
Old Sep 8, 2009 | 09:38 AM
dbilik's Avatar
dbilik
Soak it in PB Blaster, and like Dodgerules said, get a long pipe. I can say that the upper ball joints didn't give me any problems at all when I was replacing them. THe lowers were a different story.
