what size rims
Im looking at rims for my 96 dakota. The lug pattern is 6 by 4.5 correct? And if i have 235 75 15 tires on there how wide is the rims i need? I was looking at these
http://www.4wheelparts.com/WheelFind...&ab=False&pg=1
Well, a 235 is a 9.25 inch wide tire, so you could go with a 9 inch wide rim, but I would suggest 8 inches wide. You definately cannot go wider than 9 inches unless you plan on getting new tires with these rims.
I have 16x8 inch rims on my truck with 265 tires, which are about 10.5 inches wide, so an 8 inch wide rim would be fine for most tires that can fit on these trucks.
