first time wheel/tire buyer
Old Oct 12, 2009 | 11:57 PM
myfirstruckdak93's Avatar
myfirstruckdak93
Default first time wheel/tire buyer
I am planning on getting new wheels and tires for my 93 dakota 2wd V8. The only 15" wheels on tirerack.com are the Ultra Type 164's which are 15X8's so I am getting the 235 75R15 Yokohama Geolander A/T-S to fit that wheel. Before I ordered them i wanted to make sure their going to fit my dakota. Here are the specs for the wheel: Offset of -19mm, Backspacing of 3.77", and the Bolt Pattern is 6-114. Remember my truck is a 1993 Dodge Dakota LE Ext. Cab, RWD, 5.2L V8, 6ft 6inch bed. Hopefully that is enough info for you guys to determine if it will fit without any problems. I'm almost for sure the bolt pattern is correct, but i don't know about the offset or backspacing.
Thanks, Scott
Old Oct 13, 2009 | 01:01 AM
pioneerbirdy's Avatar
pioneerbirdy
If you don't have a repair book from an auto parts store i highly recommend getting one. It will tell you just about everything you need to know about the truck. If your a "back yard" mechanic you will find it very use full.
I don't have my book in front of me at the moment but it looks right. I have same year of truck and tire size is the same as mine.
Old Oct 13, 2009 | 12:59 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes the rims will fit.
