speaker quextion....
Old Oct 20, 2009 | 07:38 AM
maxwgn's Avatar
maxwgn
Default speaker quextion....
I was able to easily remove my door panels, and remove the completely rotted out OEM door speakers. The question I have is, when I looked it up, data shows the doors fit a 5.25" speaker - which i have a great set of Polk Audio 5.25" speakers ready to go in. However, they are too small - a 6.5" speaker would fit int he opening - but there are also no guide holes.
Is there an available adapter plate, or do I have to make my own baffles?
Old Oct 20, 2009 | 09:39 AM
'95Dakota's Avatar
'95Dakota
there should be an adapter plate that came with the speakers. I just bought some Alpine's and they came with them.
Old Oct 20, 2009 | 02:34 PM
skyshark186's Avatar
skyshark186
Just use a drill bit the size of the hole you want and drill holes in the speaker surround. As long as you stay a good distance away from the speaker itself youll be fine. And make sure the shavings go away from the speaker or clean them off gently.
