I need mroe lift,
Old Oct 25, 2009 | 02:04 PM
Hahns5.2's Avatar
Hahns5.2
Originally Posted by skyshark186
Lockers are good but they arent a cure all for clearance or big rubber sometimes.
But they sure make up for a hell of a lot.
Cut the fenders, low center of gravity FTW.
Old Oct 25, 2009 | 02:54 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Ya only if your burring your truck to the frame then ground clearance helps. But a locker will always help. Even if you are sitting on the frame.
Old Oct 25, 2009 | 03:37 PM
skyshark186's Avatar
skyshark186
Lol. I wasnt saying they are a bad idea. Im going to run lockers front and rear. All Im saying is sometimes big rubber is necessary. A lot of the stuff Im doing I couldnt clear the obstacles on 33's. The truck is too long and would high center very easily. A locker would make absolutely no difference if the tires arent on the ground. I need a minimum of a 35 and most likely a 37 to make the runs through the canyons I frequent.
Old Oct 25, 2009 | 05:28 PM
Jameson250s's Avatar
Jameson250s
theres canyons in nebraska?
Old Oct 25, 2009 | 05:37 PM
dakota33's Avatar
dakota33
I wish I had some good places to go offroad.. we have nothing around here..
