leveling
Old Oct 25, 2009 | 05:07 PM
dakota32's Avatar
dakota32
Default leveling
is there a way to level out the front end of my 95 dakota? my back end is about 3 inches higher than the front
Old Oct 25, 2009 | 05:10 PM
skyshark186's Avatar
skyshark186
2 or 4 wheel drive? Does the back have lift blocks or add a leaf installed?
Old Oct 25, 2009 | 05:35 PM
Crazy4x4RT's Avatar
Crazy4x4RT
If 2wd add coil spring spacers. If 4wd crank the torsion bar keys or get re-indexed ones. Check the FAQ2 in this section for tons more lifting ideas.
Old Oct 25, 2009 | 06:53 PM
dakota32's Avatar
dakota32
its a 4wd and it has a 2" lift on it. i just need more clearence in the front
Old Oct 25, 2009 | 07:13 PM
skyshark186
You can crank up your tortion bars if they arent already maxed out.
Old Oct 25, 2009 | 08:32 PM
dakota33's Avatar
dakota33
dakota32, mines dakota33... lol, made me think, why 32?
Old Oct 25, 2009 | 09:41 PM
95_318SLT's Avatar
95_318SLT
Lol, should I change mine to dakota31? :P
+1 to cranking the torsion bars. If you have them maxxed on the factory keys, you can get lift keys to crank them up tighter. The only other options besides that are a "control arm drop" lift kit like the trailmaster 4" kit (costs $2K unless you fab your own), or a solid axle swap, or lower the back to level.
