Name that screech?!?!?!
Old Nov 11, 2009 | 09:44 AM
skyshark186's Avatar
skyshark186
It means you have to pull the tranny before you drive it anymore. If there are bearings loose already the likelyhood of the bearing siezing and tearing up a bunch of parts is extremely high.
Old Nov 11, 2009 | 12:52 PM
4x4Dakota93's Avatar
4x4Dakota93
like if i grab the bellhousing and put a flat tip in gap and twist...
the 7 ball bearings will fall out, i got one out just barely spreading it apart with my hand
Old Nov 11, 2009 | 05:19 PM
skyshark186
Yeah. Thats very bad. I would pull it asap and see what the problem is for sure.
Old Nov 11, 2009 | 07:16 PM
95_318SLT's Avatar
95_318SLT
My vote based on your most recent posts is for the throwout bearing, but like skyshark said, pull the transmission out and see for sure.
Old Nov 14, 2009 | 02:14 PM
mazda7475's Avatar
mazda7475
got to be the throwout bearing. the pilot bearing is not actually a bearing it's a bushing, at least in a jeep it is, dakotas should be the same. the only other option is the input shaft bearing on the tranny and if that was the case gear lube would be pouring out from the bell housing.
Old Nov 14, 2009 | 02:17 PM
95_318SLT's Avatar
95_318SLT
On my truck the pilot bearing is a needle roller bearing, not a bushing.
Old Nov 14, 2009 | 03:58 PM
mazda7475's Avatar
mazda7475
thanks for the info. strange thing is the haynes manual calls it a bushing too. guess that shows the manual is not always right. i changed out clutches in both my 73 germlin and 90 comanchee. both where bushings so i thought it was standard for all vehicles.
