i might be crazy (billy joel)
Old Nov 25, 2009 | 07:19 PM
mazda7475's Avatar
mazda7475
Default i might be crazy (billy joel)
i thought that most tranny's where interchangeable between 2x4 and 4x4. the only difference was that they took the rear extension housing off and inserted a transfer case, few lines between the two and a shorter driveshaft. i know that different years make a difference but similar years should work? (don't trash me to bad on this one crazy)
Old Nov 25, 2009 | 07:46 PM
Crazy4x4RT's Avatar
Crazy4x4RT
You missed the part about changing the output shaft. And it has to be the same engine. But as fas as I know that is all that is needed. Yes years do matter. 92-95 transmissions are the same and 96-00 are the same.
Old Nov 25, 2009 | 08:24 PM
mazda7475's Avatar
mazda7475
your saying that as long as the years are similar and you match up the splines on the output shaft your set. not positive but i think the 87-91 3.9 are the same as the 92-96 3.9 the only difference is that on 92-96 has a cable from the throttlebody and the 87-91 has a rod. the next question is can a tranny from a 92-96 318 magmun be dropped into a 87-91 3.9. my guess is that it will bolt up but the electronics won't match up. in other words trying to put a heavier duty tranny in a 87-91 3.9 ain't gonna work!
