Transmission Slip
Old Nov 29, 2009 | 09:00 AM
Gorhad's Avatar
Gorhad
Default Transmission Slip
I have a 1994 Dodge Dakota V6 automatic.
Transmission has started slipping, so i changed the oil, pan gasket and filter, refilled the system with ATF+4 and it was fine for a few days and then started slipping again.
Any advice would be appreciated
Old Nov 29, 2009 | 11:26 AM
kahanabob's Avatar
kahanabob
Just might be time to replace the clutch packs they do wear out with time. Might try adjusting the bands. Would just tighten up a turn and see if it helps.
Old Nov 29, 2009 | 12:47 PM
ModT's Avatar
ModT
Lucas Transmission hardshift stop!
Old Nov 29, 2009 | 02:32 PM
Gorhad's Avatar
Gorhad
Tried the lucas but didnt work
Is it an expensive job to do the torque converter or clutch pack?
