vacuum problem... i think?
Old Dec 8, 2009 | 10:37 AM
blewxu's Avatar
blewxu
Default vacuum problem... i think?
i have another problem with the old girl. actually, it's a problem i've had for awhile now, but it would come and go, now it's come and won't go. the truck is lacking power. when i get on the gas, the truck feels like something is holding it back, like i'm hauling a trailer or something. if i have my heater setting to "floor", and i take off cool, all is well. but if i come after it any at all, (and with a v8 in a little truck like that a fella usually comes after it alot lol) the heater setting goes from "floor" to "defrost" on it's own and switches back to "floor" once i let off. when the weather is damp, the truck will act up even more by wanting to stall at a stop light/sign, or if i'm running down the road in the wet, it'll loose power for a few seconds then pick it back up but not without backfiring through the throttle body. i just today tried a junk yard EGR valve off a 3.9 v6. i don't know what year the truck was that i took the part off of as it didn't even have a front clip on it.... it was free so worth the try. i'm still not excluding the EGR valve as it was a junk yard freebie, but what else should i be looking at? as always, any help is appreciated.
Troy.
Old Dec 8, 2009 | 10:40 AM
blewxu's Avatar
blewxu
sorry guys. it's a 93 dakota LE 5.2L
Old Dec 8, 2009 | 01:12 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes it could be a vacuum leak. Just take a close look at all vacuum lines. If needed replace them all. Vacuum hose is extreme cheep.
Old Dec 8, 2009 | 02:22 PM
robert36's Avatar
robert36
Get u a can of wd40 an with the engine idling spray the vacum lines lightly where you think its at and listen for it to stop for a second or the rpm to change then u have found it thats the quickest way to find something like that. It works for me anyway.sorry if u have alredy tried it
