A/C Heater problem
Old Apr 14, 2005 | 07:14 PM
TexLongFan's Avatar
TexLongFan
Default A/C Heater problem
I am having problems with my 89 Dakota Shelby, no air will come out when i turn on the A/C or heater the fan does not blow at all, this morning i took apart the dash looking for the blower motor and I could not find it. I'm not mechanical enough to figure it out does anyone have any ideas on how to fix this.
Old Apr 17, 2005 | 05:42 AM
JDakota92's Avatar
JDakota92
Default RE: A/C Heater problem
The blower motor is in the evaporator box which is tucked under the lower dash. It'll be on the passenger side, and should be accessible without removing the box. Check fuses and the dash switch first though to make sure everything else is working properly. The fuse box is under the driver's side dash.
Old Jul 4, 2005 | 10:02 PM
utfan67's Avatar
utfan67
Well I'm having the same problem, I worked on getting the fan out today and was successful, I put it on a power supply and the fan runs so the problem is somewhere else.
What was you're outcome?
Old Nov 7, 2005 | 02:53 AM
360DakotaPwr's Avatar
360DakotaPwr
Check to make sure the contacts on the blower motor resistor are not coroded.
