Rear end
Old Dec 27, 2009 | 06:14 PM
Nathyne's Avatar
Nathyne
Default Rear end
I was wondering if anyone has experience setting up a rear end?
I have a 8.25inch rear end and i was wondering if you could just adjust preload and backlash if you do not remove the pinion or do you need to adjust everything again?
Thanks
Nathyne
Old Dec 27, 2009 | 06:28 PM
95_318SLT's Avatar
95_318SLT
If you don't remove the pinion, then the depth won't change... just set carrier preload and backlash. Preload on the carrier bearings should be around 70 ft*lbs and backlash should be between .005" to .008".
BTW, what are you doing? Just to let you know, it can take a long time to set the rear end if you've never done it before. Also, makes sure you have all the tools you need! The carriers in these axles are not shimmed, there are threaded adjusters that require a huge hex head tool... the size of a torsion bar.
Old Dec 28, 2009 | 01:57 PM
burntricer's Avatar
burntricer
and doing it without the J tool is absolutley NOT possible...lol ive tried!
Old Dec 29, 2009 | 10:56 PM
soar_dude's Avatar
soar_dude
Yeah Its a pain in the *** it took me two days to do mine since I had a 2X4 I don't have torsion bars so I ended up making a tool out of 1/4" plate and a 1/2" drive socket. I did not remove my pinion gear so it does made setting up the backlash much easier.
Old Jan 2, 2010 | 09:55 PM
Nathyne's Avatar
Nathyne
I had an oops with a grinder grinding out my pinion because of a broken bolt that had some threads left on it. went a little far and sliced the differential housing lol.
I am going to attempt this tomorrow... we will see anyone know the paint you should use to check the how the gears are meshing?
Old Jan 2, 2010 | 10:27 PM
95_318SLT's Avatar
95_318SLT
Its not paint, its called gear marking compound.
http://www.summitracing.com/parts/RMG-5500011/
