Rear suspension questions..
Old Jan 9, 2010 | 12:11 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Originally Posted by Crazy4x4RT
Ha Ha sucker! JK
Heck ya that is a lot of torque. Maybe its time to upgrade the leaf springs.
Old Jan 9, 2010 | 09:11 AM
95_318SLT's Avatar
95_318SLT
Oh I will be upgrading them during the SAS. And I'll probably build a pair of traction bars too.
Old Jan 9, 2010 | 03:19 PM
mazda7475's Avatar
mazda7475
guys. you lose traction on snow you will get wheel hop. it's not about traction it's all about torque. too much torque going to one wheel and none to the other you got a problem.
Old Jan 9, 2010 | 03:22 PM
95_318SLT's Avatar
95_318SLT
Thats not axle wrap though. Axle wrap is when you put too much torque and are getting too much traction for the leaves to handle. Equal and opposite forces... the wheels are trying to turn so the axle winds up the leaves in the other direction pointing the pinion up. Then it hits a point where the wound up springs unwind and it "hops" and winds up again and repeats that until you take your foot off the gas or something breaks.
Old Jan 24, 2010 | 03:57 PM
Gummer's Avatar
Gummer
Alright, the truck blew a rear brake line, so its getting a new diff. sooner than later.
Got it in the garage today. took the box off
started unbolting the rear end
Gotta wait for the new U bolts as well as cheap rear shocks ( to cheap to replace the new ranchos right now) for the blocks im putting in.
Going to get rid of that **** RABS valve on the frame and all the extra junk i dont need.
I have some pictures coming. I'll post em up as soon as i get them!
Old Jan 24, 2010 | 06:40 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Cool!
Old Jan 24, 2010 | 07:40 PM
95_318SLT's Avatar
95_318SLT
Did I understand you right.... you're getting rid of the rear ABS???
I would highly advise against that! If the rear locks up on a pickup of all vehicles, there's no telling where the rear end is going to swing out to!
Old Jan 24, 2010 | 10:56 PM
Gummer's Avatar
Gummer
Yeah man. its going.Going. Gone! haha. its overrated.. it has never locked up.. and i think the valve on the Frame is junk.
Old Jan 24, 2010 | 11:08 PM
95_318SLT's Avatar
95_318SLT
Originally Posted by Gummer
...it has never locked up...
Lol, thats why its called antilock brakes... they aren't supposed to lock up!
Trust me... a little over a year ago I did the 9.25" rear axle swap on my truck. Me and a buddy of mine knocked it out in about 5 hours on a saturday (had to line up and weld the perches on, so it took a while). We did the work at the shop I was working at at the time, and the only thing we didn't get done is splice the ABS sensors together so I'd have ABS. Of course it was raining that afternoon when I drove the truck home, and without ABS, I could not keep the truck from sliding. It was either don't stop, or slide, there was no inbetween. Having the rear end swing out on you as you come to a red light is not as fun as it sounds!
Old Jan 26, 2010 | 12:51 AM
Gummer's Avatar
Gummer
Okay... so today was a **** show.
ran the brake line. Welded up the exhaust, NO MORE LEAKS!
Then it was a mess.... I'm not going to be putting the 3.5 in blocks in the back... this was a wallet in mind build... the e-brake cables wont work.. i cant find long enough shocks ( not sure how but it happened) i was going to mod some full sized to fit it...
there was something else too.... forget right now..
But. what I am doing is adding another 1 ton leaf hah, and a 1/2 inch block... everything will fit/reach. so it will be sitting level and not drop ***...
RABS valve is gone..
Gotta get new bolts for the center of the springs...
and then bolt it up. hook the brake line up install all the new brakes on the diff, fill it. bleed brakes
pics are still MIA...
