Problems with OD (noob learning)
Old Jan 22, 2010 | 11:02 PM
  #21
TheLoBO's Avatar
TheLoBO
Ok I got this results on OBD
Error codes:
12 Direct battery input to PCM was disconnected within the last 50 key-on cycles (I really dont understand this one)
22 Engine coolant temp sensor out of range
21 02s sensor problem
33 A/C clutch relay circuit (A/C gas ran out)
13 No change in MAP from start to run
52 Fuel system rich
55 End of codes
Old Jan 23, 2010 | 02:27 AM
  #22
Crazy4x4RT's Avatar
Crazy4x4RT
Damn. Well 12 is normal. But the rest is not. I would suggest unplugging the battery to reset the computer. Then see which ones comes back. Some may just be a fluke. The ones that return, replace the sensor it says.
Old Jan 23, 2010 | 02:33 AM
  #23
95_318SLT's Avatar
95_318SLT
+1 to that!
I still don't see how the computer even allows the OD shift after seeing all the codes thrown.
Old Jan 23, 2010 | 07:47 AM
  #24
azvampyre's Avatar
azvampyre
I thought pushing the OD button turned off overdrive?
Old Jan 23, 2010 | 09:38 AM
  #25
tmacdakota's Avatar
tmacdakota
Pushing the OD button does turn off OD.
Lobo...do as suggested. Disconnect the battery cables for about 15 minutes, then hook them back up...this reset's the computer under the hood. Drive it for a couple of days, then pull the codes again...any that return need your attention. At worst, you're looking at an engine coolant temp sensor, O2 sensor(s) and MAP sensor. Any or all of these could cause a rich fuel mixture. Before you replace a sensor, check its electrical connector to make sure its working before you assume the sensor is bad.
Old Jan 24, 2010 | 05:36 PM
  #26
TheLoBO's Avatar
TheLoBO
Cool
YESER!!! Ill do it, thnx
Old Feb 10, 2010 | 01:45 PM
  #27
TheLoBO's Avatar
TheLoBO
Fixed it the vibration was just a broken U joint I noticed that parts even have a small oliers (graceras). Jesus, all the services that Im giving to my truck are the first ones!!damn!
