Buying a Dakota; Advice?
Old Jan 25, 2010 | 05:02 PM
rolla91's Avatar
rolla91
Now it seems to work fine again with no issues.. Ha this thing is insane, I'm thinking I should've stuck to toyotas, at least when they break, they break. I guess I'm going to just pull the shift linkage off and manually shift it to drive and see if it continues to drive and shift.
Old Jan 25, 2010 | 09:13 PM
rolla91's Avatar
rolla91
It looks like I'm mostly replying to myself on this forum but I thought I would show you guys a picture of my 100$ Dakota.
Its a little rusty but mostly on the bed.
I'm hoping to lift it and have it sitting on some 31"s or 33"s and hopefully a little bigger, and maybe eventually better than my old Explorer I lifted two years ago.
Here it is before
And a few After
And I might as well throw in some video of me thrashing the poor lil V6 =)
Old Jan 25, 2010 | 09:35 PM
95_318SLT's Avatar
95_318SLT
Originally Posted by rolla91
It looks like I'm mostly replying to myself on this forum...
Lol, well it could have something to do with saying:
...I'm thinking I should've stuck to toyotas
Probably no one here had anything constructive to say about that.
But anyway, looks like a good deal you got there! You really won't be able to fit much bigger than 33s on it without doing some serious fabricating, like a SAS or control arm drop kit.
Old Jan 25, 2010 | 11:10 PM
rolla91's Avatar
rolla91
I wasn't meaning anything by saying I should have stuck with toyotas other than that I have very little knowledge about dakotas and its going to be mostly new from my past.
I assume I'll learn though.
I measured the wheel openings earlier and I believe that with a 3" body lift, TT, 1" rear blocks and Add a leaf 35s would barely clear plus when I remove the rust I'm planning on just cutting away the front and rear fender wells where it flares. I know the IFS wont take much abuse but a SAS has crossed my mind for sure. It just depends, my original plan was to get this to be my work truck/beater but as history has shown I am just not able to own anything that is not modified.
Old Jan 25, 2010 | 11:25 PM
95_318SLT's Avatar
95_318SLT
Actually, the IFS can handle more than you think! Just look at Blue_12's truck and the 38s he's got stuffed under it! With the 3 inch body lift you might be able to get 35s under there. If 33s will clear with the 2 inch lift, that extra inch will give you the extra inch for 35s! But do you already have the 3 inch body lift? Cause the company that made them before ended production of them and now all that is readily available is the 2 inch lift.
Old Jan 26, 2010 | 08:17 AM
rolla91's Avatar
rolla91
I was just going to make my own kit. A body lift mostly just consists of the blocks, bumper brackets, and the bolts to hold it together and you can buy enough 3" blocks off ebay to lift it for around 30$
I'll need to buy longer bolts and I'm not sure about the dodge but on my Explorer I had to extend the steering shaft. It will all be easy and lots cheaper than buying the bolts and blocks together in a kit
I saw his truck on the 38"s but wow I just cant imagine my lil V6 on IFS dragging those huge tires along no matter how its geared. I guess I will just have to watch and see how his holds up to plan where mine is going
Old Jan 26, 2010 | 01:00 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Ya you can always build it your self. I believe Blue12 didn't change his gears to run the 38's.
