95 dakota fuel gauge problems
Old Feb 15, 2010 | 03:52 PM
vlc92189's Avatar
vlc92189
Default 95 dakota fuel gauge problems
Hey guys I have a 95' Dodge Dakota and the fuel gauge isnt working. it spikes once in awhile but 98% of the time the guage is sitting at E.
any possible causes or is this common among these older trucks?
Old Feb 15, 2010 | 03:55 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes this is a common problem. It is a tab that get corroded. Check the FAQ in this section for a write up on it.
Old Feb 15, 2010 | 05:46 PM
vlc92189's Avatar
vlc92189
sorry but when i looked i didnt find a write up, but all i found was this.
Fuel gauge doesn't work- A common problem in these trucks are gas gauges that put out erroneous readings. (This problem is common to not just the Dakota, but also the Rams, and many other Dodge vehicles) Some people have had luck with running fuel system cleaner (such as "Chevron Techron"), that might at least help the issue. While doing other fuel tank maintenance, erock92kota discovered that the tabs the unit rode up and down on were messed up, he simply snapped them back in place, and his gauge works again.
Unfortunately, at some point, they integrated the fuel sending unit with the fuel pump, so not all years have a separately serviceable sending unit.
and my question, that tabs is he referring too?
