Early dakota brakes, 2 sizes
Old Feb 26, 2010 | 01:15 PM
bill55az's Avatar
bill55az
Default Early dakota brakes, 2 sizes
I was wondering how easy it might be to upgrade dakota front brakes. On a lot of older Mopars, you just put on a different caliper adapter/bracket, and it moves the caliper out a bit allowing for a bigger rotor. I see that Dakotas have a similar adapter, so it follows that we SHOULD be able to do the same thing.
Anybody here an expert on the brakes?
Old Feb 26, 2010 | 01:45 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Without seeing an early Dakota set up, I don't know. I would say head out to a junkyard and take some measurements. Also you can go to www.autozone.com and check if the early and later years have the same part numbers.
