I have to do WHAT?!?
Old Feb 26, 2010 | 04:17 PM
Yeoman3.9's Avatar
Yeoman3.9
Default I have to do WHAT?!?
This website i found (http://autorepair.about.com/library/faqs/bl619e.htm) says that i have to pull the whole gas tank off just to replace the fuel filter.....is this true?!
Old Feb 26, 2010 | 04:20 PM
95_318SLT's Avatar
95_318SLT
Either that or take the bed off and attack it from the top. But yes, the fuel filter is integrated into the pump/sending unit.
Old Feb 26, 2010 | 04:21 PM
eddys89vert's Avatar
eddys89vert
sounds about right. lifting the bed off is actually easier for me.
Old Feb 26, 2010 | 04:46 PM
Yeoman3.9's Avatar
Yeoman3.9
well dang ....so much for an after work evening job....sounds like this is going to to be a most the day saturday job.....
Old Feb 26, 2010 | 04:58 PM
festerw's Avatar
festerw
Don't know if your 93 is the same but mine has the fuel filter mounted inside the frame rail on the drivers side. If you've got the canister looking one in hand that's where it goes, the one on the fuel pump is different.
Old Feb 26, 2010 | 09:30 PM
dk sport's Avatar
dk sport
festerw is rite 88-91 whitch is what i have has a prefilter in tank and a reguler filter under driver seat with both lines on the same side i replaced the fule line while i was in ther 20 year old fuel line cant be in that good of condition supply is 3/8 and return is 5/16
Old Feb 26, 2010 | 10:37 PM
mmanahan1's Avatar
mmanahan1
thats where mine is
Old Feb 26, 2010 | 11:50 PM
Crazy4x4RT's Avatar
Crazy4x4RT
93 and down have an external filter, as well as an internal filter. The sock kind if I remember correctly.
94 and up only have one in the tank like an air fliter type.
Old Feb 27, 2010 | 12:18 AM
Yeoman3.9's Avatar
Yeoman3.9
Y'all Rock! @Festerw Right after your post I ran outside and slid under my truck sure nuff it was right under the driver side door, dude, i could have kissed you right then. I grabbed the filter and within minutes had it in. I was really dreading pulling the bed off.
Thanks a ton guys.
Old Feb 27, 2010 | 10:26 AM
bill55az's Avatar
bill55az
But if you had to pull the bed, you don't have to pull it OFF, just disconnect the wiring and remove the bolts and slide it back a bit. I had to do it to replace the fuel pump.
Factory manuals can be misleading. Mine told me to remove the AC condenser to get at the transmission cooler. Makes a lot more sense to remove the radiator, not the condenser.
